m not running on all 4
dslfarmer
I Have a super m that is not running on
all 4. It has spark and gas. Could the
valves be out of adjustment so far they
would be causing problems? What is the
adjustment supposed yo be on the
valves. Thanks
.017 hot, try .020 cold to get you in the ball park. run a compression test on the cylinders, could be burnt valves, bad head gasket, bad rings ect.
As Glen says but to save you some time and work you might try a could other things first. #1 find which cylinder is not firing then do things like compression check on that cylinder and also more say the plug wire from one you know works to that one that is not working and also move the spark plug. You could have a bad plug wire or a bad plug or for that matter a bad distributor cap
Could also be burnt valves, or carbon build up on the valve stems which will prevent them from fully closing.
Don't rule out a faulty spark plug or plug wire either. Just because they are new does not necessarily mean they are good, and just because a spark plug has fire when you test it outside if the engine does not necessarily mean it will fire when it is in place.
If it's a consistent dead miss run compression first. That will tell you if it's a mechanical issue. If compression is good, 10% of rated pressure and 10% of each other, you know it's related to either fuel or spark. Affected cylinder needs to have blue spark which jumps a 1/4" gap. Use the old plug for this test and clamp it with a vice grip to bare metal. If that's good, it's probably fuel related. Hope this helps Gerard
Thanks for the help after taking the cover off and seeing how bad the valves were out of adjustment we started there. That fixed the problem! Runs well now. I also checked compression, what should it be around? The previous owner claimed to have new pistons and rings in it.
a weak motor but still running may have around 80 psi. 100-125 is decent. over that its real good. they were low compression engines to start with, so you shoulndt see extremly high cylinder pressures unless there were some "goodies" installed.
