M oil filter cover
BigTone
Can anyone tell me how tall the oil cover is on there m? I have ordered 2 so far and both have been to small, approximatly 4 inches and the one i have on mine is like 7-8 inches (the tractor is miles away or id go measure it myself). i just want to make sure that the cover i have is the original, im almost positive it is but i would love for someone to confirm it for me.
thanks for the help....
Sounds like you are getting short ones for most H tractors and for SH through 350. M only used the tall cover though early ones were a bigger diameter like the diesels than what most M tractors use.
(quoted from post at 19:18:52 11/30/11) Sounds like you are getting short ones for most H tractors and for SH through 350. M only used the tall cover though early ones were a bigger diameter like the diesels than what most M tractors use.
Exactly. My 1940 M has the cover that is larger than all the other Ms. The filter it uses is the same as used on the 600 and 650.
I have the tall one too. Mine measures 7 1/2 inches from the bottom of the bolt head at the top, to the base flange the cover fits down into.
OIL FILTER CASE (S/N FBKM 501 to 59393)
The parts book lists 2 different housings.
This one is the same as my MD.
It is 8"tall to the bottom of the top bolt and is 5" in diameter.
OIL FILTER CASE (S/N FBKM 59394 up)
Is the other listed and I have no idea on size.
Edit: 47M's looks skinnier.
Maxx
