manitobafarmer12
Got a 670 super trying to lift deep tiller moves it about a inch then stops can hear pump working and the opposite hose gets rock hard. Have a blade on it and the cylinder cycles fine
Tried different couplers samething. It's 4 hydraulic cylinders it's gotta liftSounds like a coupler not working right. "Opposite hose" is building pressure because return oil isn't making it back into the system. Maybe just a bad male tip. Not all that uncommon.
1350 psiPut a pressure gauge on outlets. Should be 1200 psi plus.
On all 4 outlets? If it is your problem external.1350 psi?
Only have 2 outletsOn all 4 outlets? If it is your problem external.
Two pair? Two positions on each. Type E?Only have 2 outlets
Yes 2 pairs so 4 outlets but only have tips on one set. Forward neutral and backTwo pair? Two positions on each. Type E?
Have 1350 in both directons?Yes 2 pairs so 4 outlets but only have tips on one set. Forward neutral and back
No 3pt. They're a case coupler and I'm running converters to pioneer tipsDo you have 3pt ????? show a closeup of the couplers on the back of the tractor.
I would check the hydraulic couplers and also check the hydraulic lines from the valve to make sure you aren't going against the valves, meaning working against each other in a single or double acting cylinder.No 3pt. They're a case coupler and I'm running converters to pioneer tips
Yes using those couplers. I've tried a single cylinder and it works fine just on the ones with more than 1 cylinder it won't lift etcYou said you have a blade on it also. Are you using same remotes and couplers for blade? Try another implement or cylinder with same dimensions as deep tiller.
That's what I'm thinking. Might switch couplers around to new ones instead of running adaptersIn your first post you said the tiller moves about an inch, you here the pump working and the opposite hose gets rock hard. As Harry said in post #2 that sounds like a coupler issue not allowing oil to return to the reservoir. I added in post #16 that being in the wrong coupler or a valve set up for single acting might do it as well.
You can take the coupler end off of the hose that gets rock hard, get the hose end anchored in a bucket to catch the oil and try lifting it. If it lifts and oil goes in the bucket your problem is a blockage from that coupler back to the valve and tractor.
Much better idea, it eliminates one possible blockage point in each hose run.That's what I'm thinking. Might switch couplers around to new ones instead of running adapters
