G1355
Going to look at m670 gas with loader tomorrow needs rear rim so wont really be able to drive it anything to look out for? if torque dont work in low range are they expensive to rebuild and are parts readily available thanks
Not if you know what your doing on the torque and if it does not have a lot of damage. The only real test I know of is under a heavy load.
Did the torque on a 670 super not to long ago, high side cost $300-$500, new low side sprag bearing from agco was $1000, so we found a used one. If you have to fix a torque, get with River Dale Farms they have the parts considerably cheaper. Not hard to do easier than IH t/a in my opinion. Just have to split the tractor like doing a clutch.
