Caryc
I've heard the subject of hard to read aluminum ID plates on tractors or loaders. If you have a digital camera with a "macro" setting on it, you can take some pictures of the id plate from different angles.
Then you need a photo editing program. Open the best looking picture and play around with your light and dark settings and your contrast settings. You can usually get the number to show up enough to read it.
Below is a picture of the ID plate on my MF202 loader. In my editing program, I adjust the light and contrast and enlarged the picture larger than you see it below. Outside on my loader I looked at it with my glasses on and even a hand held magnifying glass but was unable to read the model number.
But on the picture below I was able to make it out. It's model 102M. I hope this hint may help some of you.
This post was edited by Caryc on 09/02/2021 at 07:47 pm.
A good tip Caryc , I've often altered contrast and light but have not started with a Macro photo . UK made TEA versions are notorious for having impossible to read plates . Crack inspection X rays are a real solution for the worst of them but it's a difficult task to organise.
This post was edited by Charles in Aus. on 09/03/2021 at 02:00 pm.
Thanks, It didn't help that some previous owner had used a wire brush on the tag to get through the paint. :cry:
