Mag drive bearing
A,B,C and otherS all use it so you will need to get it from your I-H dealer. You will need something to install it so you dont burr the edges. Do you want a used one as they arent worn as a rule. Got to be careful installing to get the oil passage lined up.
The CIH part number is 43439DBR, should still be readily available through the dealership for some $50, or GOOGLE "IH 43439DBR" for many on-line sources. (Looks like they are mostly more $ than the dealer!)
