roy prins
I have a four cyl. kohler engine with a magneto -- no spark -- so I know the points need cleaning and while Iam in there I would like to test the coil -- can some one tell how to check the coil? It is an american bosch Mag. simple one wire into the coil ___ Roy
Two things: With the lead to the points disconnected, or a plastic knife between the points, there should be very low resistance to ground. (use an Ohm Meter set to RX1. Probably near one to 2 ohms. There should be much higher resistance between the high voltage tower, and ground. Probably more than a thousand ohms. A reading is good, Infinity (open) in not good. If these are OK, the real test is output of spark. The other tests just keep bad internal wiring from letting you go beyond that. Good luck. Jim
Clean or replace the points and the odds are in your favor that the mag will work.
Next likely point of failure would be the condenser.
Jim told you how to make a basic test of the coil, and even if it passes the basic Ohms tests it may fail to produce a good spark.
If there's even one "shorted turn" in the windings of the coil it won't throw the Ohms readings out of the normal range, but in operation it will convert what should be spark energy to heat, making for a non-existent or weak spark.
The only (reasonably accurate) way to test a mag (or Kettering ignition coil, for that matter) is with a tester made for the purpose that "rings" the coil.
If it has even the slightest internal short, it will fail the "ringing test".
In my manual it says test by substitution. Try another coil. If you play with mags you keep a spare new coil. Coils don't go bad often.
