I ordered a set of main bearings for my TO20 rebuild knowing it would be the shell type with a thrust washer to take the place of the flange. What I did not know was the thrust washer was not a brass washer but a fiber washer.
I do not like the look of the fiber thrust washer. The bearings are an actual Massey Ferguson main bearing set, so I presume the fiber thrust washer was used in many rebuilds. Is it OK to use or should I order another set with the flange attached. I thought I read on here somewhere that the fiber thrust washer would compress some over time allowing endplay in the crank shaft. If I could find a brass thrust washer I think it would be more durable but I have not found a source. Should I get a flanged set of bearings instead?
After I get the tractor restored I plan on giving it to my daughter and son-in=law to use. They will bush hog 5 acres twice a year and use the grader blade some to maintain a gravel road. It will not be worked like it was paying for the farm back in the day.
