Main Bearings
Mike72
I need .010 oversized main bearing. If they still have any or where they might be.Any help would be very helpful.
For a 1949 JD model B late engine. The crank was turned .010 on the mains and rods. I apprecite your help greenmachineman.
Mike
Mike, if your tractor originally had split, babbitted main bearings you will have to find some main bearing housings from a later B or 50 tractor that take the one piece main bearing. Once you find these you will then have to get some new main bearings and have them sized for your crankshaft. Unless something catastrophic happened it's very rare to have to turn the mains on these tractors. You will need some more parts, it appears. Mike
Better try to find an UNDERSIZED bearing instead, as things are gonna fit awful loose if an OVERSIZED bearing is used!
