main drive outer bearing
I have a 49 farmall H and the main drive seal keeps leaking trans oil , put a new bearing in ,new seal ,also checked the drive end where the drive shaft bolts on for seal wear . Was asking would it hurt to put a sealed bearing just on on side to keep grease from leaking out . Thanks for any help. Scott
May not hurt anything but you probably have a groove in the shaft where the seal rides that will cause a leak , might be able to shim it out a hair and get it to quit leaking.
