Making Rear Tires Round
2510Paul
My 4250 has a pretty good hump in the rear tires going down
the road even after plowing a field. What procedure do you
use to make them round?
I just had the wedges moved to the inner bevel, it is worse
than it was before.
Thanks, Paul
If its worse after you moved it you need to jack the tire up and put a block of wood a couple inches from the tire and roll it and make sure the tire stays the same distance from the block the entire revolution. As far as the hump no you cannot get rid of it i have one like that and it just keeps getting worse.
look at the bolts and nuts holding the wedges in place. Some will show more bolt thread than the others. Loosen the nuts that show alot of thread and tighten the ones that don't show much thread.
