manifold nuts
Jim N.W.Mi
Hi all,
Replacing manifold on my 8N. When removing the old manifold there was flat washers behing two nuts,a split lock washer behind one and no washer behind one. When I install new manifold should I use flat washers or no washers at all. I know to tourque to 27#. Thanks in advance for your help.
Jim.........according to my N-Ford MPC (master parts catalog) the N-exhaust manifold is held on with p/n: 351436-S7, 7/16 lockwasher; and of course the p/n: 33816-S, 7/16-20 BRASS hexnut torqued to 27ft/lbs........Dell
The 351436-S7 lock washer is an interesting beast. It looks like a standard helical spring steel lock washer, .446/.464 I.D. and .784 max OD, .109 nominal thickness, but it had the snagging corners (what would tear up the brass nut on removal) ground off 3/32 back from the ends at the split. I have never seen this on a Ford lock washer drawing or in a fastener standard before, but looks like a great idea to me.
