Manual for Yanmar F24D !!
Status
Not open for further replies.
Thank u for the answer...but i am from Republic of Moldova ( it is near for Ukraine ) and i don't think that they ships to ny country.
Maybe anybody has in the electronic format the diferent manuals for Yanmar f24D ? Please send to my e-mail <EMAIL email="[email protected]">[email protected]</EMAIL>
Sorry my english.. Thank u all.
<QUOTE author="flash440"><s>
</s>Thank u for the answer...but i am from Republic of Moldova ( it is near for Ukraine ) and i don't think that they ships to ny country.
Sorry my english.. Thank u all.<e>
/e></QUOTE>
I don't believe you will find electronic manuals for your tractor'
http://www.hoyetractor.com/canada.htm
<QUOTE author="alan"><s>
</s>They will ship anywhere.<e>
/e></QUOTE>
Thank you all. Can any body to explain me, what is the number on dash board ( 1,2,3,4 ) under the tahometer (lower pointer ) Sorry my english !! <E>:)</E>
"Sorry my english" Nu este o problemă.
Numbers 1 to 4? I don't know. Can you describe them more?
</s>"Sorry my english" Nu este o problemă.
Numbers 1 to 4? I don't know. Can you describe them more?<e>
/e></QUOTE>
Speak romanian Alan ?????
Acush vedem. Am in vedere pe spidometru este impartit in 2 jumatati in cea de jos este 1,2,3,4 inteleg ca sunt vitezele..ceva de tipul acesta....corect ?
</s>Vă poate arăta o fotografie?<e>
/e></QUOTE>
Iata am o poza unde am indicat cu sageti despre ce vorbesc eu Alan.Din start iti multumesc pentru raspunsuri si colaborare. De unde esti ?
Sorry, guys, I was trying to get clarification of the question before translating. He basically asks in the photo what the lower half of the speedo display is saying, and what that thing by the clutch pedal does.
Nu știu nici, dar altele de aici sunt mai inteligente. (I don't know either answer, but others here are smarter than I am.)
Sunt în Canada, la vest de Toronto. (He asked where I am.)
Hope somebody can help. Nice-looking tractor, and good work with the printing on the photo.
I am not sure of anything but I sort of think the lower part of the tachometer/hour meter is a read out for PTO rpm in the different ranges.
I am unable to see exactly what is being referred to down around the clutch pedal. Could it possibly be the clutch lock? (Hold the clutch down lock)
Just elaborating Winston's answer:
Winston se întreabă dacă arată viteze de priză de "PTO."
În cazul în care stă încă o săptămână pedala ar trebui să fie ținut în jos sau părțile pot bloca împreună. Winston se întreabă dacă ceea ce indica este mecanismul de a deține pedala jos.
Winston se întreabă dacă arată viteze de priză de PTO."
Sorry if this is a duplicate -- doesn't seem to be any way to cancel a posting.
Winston I believe you are right about the PTO rpm's That is what is on the bottom of my tach. it shows the PTO rpm's at a set engine RPM for each PTO speed.
<QUOTE author="winston"><s>
</s>I am not sure of anything but I sort of think the lower part of the tachometer/hour meter is a read out for PTO rpm in the different ranges.
I am unable to see exactly what is being referred to down around the clutch pedal. Could it possibly be the clutch lock? (Hold the clutch down lock)<e>
/e></QUOTE>
No no..the second arrow is not referred to the clutch pedal. Near the clutch pedal are a piece which need to pool
Sorry my english,hope u understand what i mean.
</s>Ok..and where is the tractor's speed idicated (km/h) ? Or it is not indikated ?<e>
/e></QUOTE>
Speed is not indicated, only engine rpm on the top scale.
</s>Thank u winston...ok
And what about the second arrow on the foto ??? Maybe u know what is this ?<e>
/e></QUOTE>
Only guessing. Could it be the compression release??
Acesta este modul de a decide dacă săgeata doua este eliberarea de compresie. Dacă vă trageți-o către dvs. și rotiți cheia, motorul se va transforma rapid, dar nu va porni.
(Your model is rather rare over here, so we only guess it's the CR. If it is, pulling it toward you and turning the key results in a fast spin but no firing.)
</s>Acesta este modul de a decide dacă săgeata doua este eliberarea de compresie. Dacă vă trageți-o către dvs. și rotiți cheia, motorul se va transforma rapid, dar nu va porni.
(Your model is rather rare over here, so we only guess it's the CR. If it is, pulling it toward you and turning the key results in a fast spin but no firing.)<e>
/e></QUOTE>
Ok..but i i don't understand for what is this ("pulling it toward you and turning the key results in a fast spin but no firing" ) ?
In whitch case it need to do ?
Dacă se merge de mai sus motorul, trăgându-l indeparteaza de compresie în cilindri. Acest lucru permite de pornire pentru a porni un motor rece rapid. Să mergem, se întoarce de compresie, și este de cotitură suficient de repede pentru a începe.
(He indicates it goes to a cable, so could be the CR, which I tried to explain.)
</s>Dacă se merge de mai sus motorul, trăgându-l indeparteaza de compresie în cilindri. Acest lucru permite de pornire pentru a porni un motor rece rapid. Să mergem, se întoarce de compresie, și este de cotitură suficient de repede pentru a începe.
(He indicates it goes to a cable, so could be the CR, which I tried to explain.)<e>
/e></QUOTE>
Salut
</s><QUOTE author="alan"><s>
/e></QUOTE>
Nobody have'nt manual for htis or similar tractors ?
/e></QUOTE>
Does the cable have another end?
Yanmar nu oferă manuale pentru tractorul în limba engleză. Dar există una mai generală pentru seria F. Hoye se vinde pentru 40 dolari, plus transport maritim.
(Explained how to order the closest manual.)
</s>Yanmar nu oferă manuale pentru tractorul în limba engleză. Dar există una mai generală pentru seria F. Hoye se vinde pentru 40 dolari, plus transport maritim.
(Explained how to order the closest manual.)<e>
/e></QUOTE>
Clar..am inteles..gindeam ca poate cineva are in format electronic,si nu ii jale sa-l dea ! De aici din moldova e mai problematic cu webmoney sau nnalert se vine prin PayPal...la noi sistemele acestea nu prea lucreaza..
He explains it's hard to pay from where he is (Paypal and the like don't work), which is why he had asked if some savior could send the manual electronically.
</s>He explains it's hard to pay from where he is (Paypal and the like don't work), which is why he had asked if some savior could send the manual electronically.<e>
/e></QUOTE>
Thank u Alan. !!! He is my translator . <E>:D</E> <E>:)</E>
I'm sure Western Union, (wire transfer), is all over the world: however I strongly doubt that any non-OEM manual you would purchase would hardly be worth the expense.
Experții noștri spun cu siguranță, nu este un mod de a trimite un pic de bani. Dar ei nu știu cât de bun este manualul neoficial.
(Last comments of our two top experts.)
</s>Experții noștri spun cu siguranță, nu este un mod de a trimite un pic de bani. Dar ei nu știu cât de bun este manualul neoficial.
(Last comments of our two top experts.)<e>
/e></QUOTE>
Thanks to all for the answers..very nice conversation. Once again THANKS !!!
Status
