I have used a ground-driven IH-100 40bu manure spreader for the last 25 years, running the same ag tires that were on it when I bought it used at auction. Alas, spreading heavy loads of wet manure last weekend broke the chain (second time in 25 years) so that needs fixing, and the tires are basically shot from dry-rot with the tube showing through the cracks. The ones on it are marked 5.50x16 (same as manual shows), and stamped 4-ply rated Goodyear traction implement. Replacement 4-ply tires are relatively inexpensive, but I am concerned over the load rating. Current 4-ply tires are marked load range B and say 620lb load. Has that rating changed? If that is what I've been using, it certainly has held up, but it seems 40bu might require more like a 1000+lb rating, and those move into 6-ply load range C tires that are 3-4 times more expensive. Am I OK staying with 4-ply tires?
