This is a gas 4 cylinder Continental. The tractor has not been run in maybe 4 yrs. I have it running but there are no hydraulics. There is no 3pt response. I have moved both hydraulic levers up down several times and nothing. It does not even try to lift. The oil level is on full before someone asks. It also has the auxiliary valve so it can operate a rear remote cylinder. The draft control lever on the side of the trans by my right foot is in the forward position if that makes a difference. What should I do before I get inside of this. I can borrow a manual on this tractor if I have to go inside but there must be something I have over looked because the owner told me it worked OK before he parked it. Thanks in advance.
