(quoted from post at 06:45:17 10/28/14) what do you have to take off to change plugs on a massey 135 3 cyl.
I have a MF 20 industrial and am told that it is basically a MF 135. I changed the plugs in my 3 cyl. gas Perkins without removing anything except plug wires. The gas tank front bolt is difficult to remove so I left it alone. You might want to have a small shop vac nearby before removing the plugs as crud builds up around the spark plug and could fall into the cylinder. I loosened the greasy crud and a mud dauber nest with a small screwdriver first then vacuumed around the plug before removing. Changed the plugs with new ones in about 10 - 15 minutes. Hope this helps.
