massey 20F flywheel thickness
I have a flywheel that needs approx .100 machined off to make it flat. The book says .040 max. I"d be willing to fab a shim between the wheel and crank if it would otherwise work. About 400 for a new one.
thanks Mike
on the same subject, the 20f has several clutch discs available. The metallic one is called out by MF but all the rivets sheared and tore up everything. Would a regular organic be better? It"s a lot cheaper.
