massey 230 hydr problem
roviscanec
I got a 230 mf I got the side cover off and it dosent look like either of the controls that the book shows I think it is a non psi setup an I need to no if theres any way to adjust the psi its only putting up 1000 psi an wont lift the 800lb weight I am a mech but new to massey tractors an this is the first one ive seen like this if anyone else can help please do
With the tractor engine running,and controls in the raise position,look in through the side cover and see where there is oil either dripping down or turbulence in the oil around the pump.A word of caution-do not stick your hand or any other part of your body inside of the housing-high pressure oil will harm you. Joe
