MasseyPerkins
Tractor died. I was low on fuel but only just touching the red.
Filled up with diesel and no fuel coming out of pump bleed.
No fuel coming out of filter housings after filters removed.
Fuel coming out of fuel tank drain tap.
Blew out air in tube coming from lift pump to filter, no blockage.
Fuel coming out fine from tank to lift pump, but no fuel coming out of lift pump exit.
Took off lift pump, soaked in petrol. Blew air into inlet, diesel blow out from lift pump exit.
Put inlet line back into lift pump, just a few drips coming out of lift pump exit.
Put lift pump back on, connected all lines and tried to use lift pump to send fuel to filters but only a few drips at filter housings.
Don't understand if I can easily blow air/diesel through lift pump, why gravity fed fuel is not getting through. Lift pump was replaced a few years ago and was genuine Perkins.
