Grtrnd11973
Been on here a few times and you all helped me in the past and it's appreciated. I'm back again. I have a 265 that has the power steering pump on the side of the engine, orbital steering valve with 2 lines running up front to a single cylinder attached to a steering arm that is splined to fit over a drop shaft that goes down under the tractor for the tie rod tubes. I broke my steering arm and ordered a new one from my dealer. Installed it today and my steering will go sharp to the right and not sharp at all to the left. Took the battery back out and if the wheels are straight ahead the chrome part on the steering cylinder is only sticking out about 2 inches, max. The splined shaft has a 1/4 inch with no splines so it will only line.up and slide down on the shaft one way. I'm at a loss here unless they gave me the wrong steering arm. Any ideas? Thank you
