massey 2705 loader
gareth
I have a massey 2705 that a loader was just put on, hooked up to the rear remotes currently but i would like to put a loader valve on it and I'm wondering where to plumb it in to?
On the left side control valve, there should be a 5? long L shaped 1/2 steel tube that comes out of the pump cover and goes to the valve. You can tie in a power beyond valve there.
At least that is how my 2805 is. If I remember I will go take a couple pics. Mine is set up with 2 single spool valves. One run from the left pump and one on the right side. Have sorta decent speed that way.
Left side pump connection, red is pressure, green is power beyond from the loader valve. On this side make sure there is a relief in the loader valve as it connects direct to the pump.
Right side is connected to the feed for the three point. I think this one would be protected by the relief on the third valve if you have one.
Returns are connected to an original tee that was modified. Yellow
At least this is how I have my 2805 set up. Yours may be different.
I have my valves mounted under the side of the cab, and a joystick on the window frame.
