Massey 85 powersteering pump issues
JJL
I am having problems with the powersteering pump on my 85. I took it apart and cannot see anything visually wrong. There are no damaged teeth or wear marks on anything. If I put the pump in a pail of oil and spin by hand, oil squirts out, but when it is installed I have not oil pressure in the lines at all. Any ideas on what to look at?
If yours is like the one on my 65 there are 2 small gears inside one has a keyway the other has a shear pin. On mine the shear pin broke. Hopefully thats the problem.
on the underside of pump there is a threaded plug that is held from turning by a small roll pin. remove roll pin. turn plug out to remove count the turns. there will be a spring and a valve and body. remove valve with body it is probably stuck. once you get the valve unstuck clean and polish untill it moves freely in body and reinstall
MHF..... THANK YOU!! This was the problem. In fact, I had a second pump on the shelf from about 12 years ago that did not work. I pulled the valve body from that one and fixed that one too!
