Massey ferguson 1135
Schnautz
Having trouble with the 3 point lift arms will not stay in set position I find that I have to keep compensating. where do I start looking to correct the problem. It"s impossible to plow this way. Any help is appreciated.
May need to adjust the top link sensitivity per the owner's manual, there's a pin that can be set in three different positions. Also make sure the leaf spring bolts are not broken, three on each leaf. Could be the three point A frame arm end pins are in the wrong holes too, lower holes will not make the top link sensing work, arm ends need to be in the upper holes so the system will work correctly.
