Massey Ferguson 135
koenton
Having trouble starting, will click a bunch of time then will finally start, would that be the starter solenoid, it will do that every time I try to crank the M.Ferguson 135 tractor
Poor connection at the battery of ground or weak battery or your cables are going bad or yes the solenoid or starter could be going bad. I'd start by cleaning up all connections since that is cheap
Try the solenoid bolt turn like I mentioned before, solenoid does not even need removed from the starter to turn the bolt. If all connections are good, but it takes five/ten tries before starter kicks in that's USUALLY the solenoid top bolt head worn on one side.
To Old
Thanks for the reply, I am going to check the reply today, it has been raining every day after i received the help, sure do thank you all for the reply, i was going to order me a solenoid, but i want to check all the places i received, will let you all know what i find
Thanks to everyone that answered back to me.
(quoted from post at 18:25:15 08/25/22) Try the solenoid bolt turn like I mentioned before, solenoid does not even need removed from the starter to turn the bolt. If all connections are good, but it takes five/ten tries before starter kicks in that's USUALLY the solenoid top bolt head worn on one side.
I tried the solenoid bolt turn today it didn't do anything so i did it again then it did the same thing just click, so i turned the post again, it quit clicking so i jumped the to post on solenoid & starter
and finely got it to turn over & crank after it cranked it would crank with key, tried to times and it would start right up, so i think that fixed my problem. Thanks so much for the info.
Will in Al
