Massey Ferguson 150 deisel tractor
Max Grant
I have a Massey Ferguson 150 tractor. When I start the tractor--oil comes out around the dip stick. WHat is the problem???
try posting this question on the MH/MF discussion board here. That's where the MF experts reside. I have a MF 135 and 165, and you could first check the breather tube that comes out of the top of engine. If the tube is crimped or clogged it will create too much backpressure. Its happened to me. Disconnect breather tube and clean out and make sure the tube exit point is clear. Also, after cleaning try blowing into tube to check obstruction in cover screen where tube originates - but you must remove oil filler cap first when doing this. Like I said, post this question on the MF board and there are many good folks there to help you with your MF 150. Good Luck.
This can be caused by an overfilled crankcase (too much oil, diesel fuel or coolant getting into oil).
