massey ferguson 175 sputtering
Friend has a 175 massey fergusson gas tractor that will not run right.
He has replaced plugs, points, condenser, dist. cap, coil, no change.
Had the carburetor off twice every thing is clean and all ports and even the smallest holes in the jets are clean .
.The problem started a few months ago while using it to push snow. It wold run fine on start up and after it warmed up it would start to miss and sputter.Every time he used it it would start to miss a little sooner, until eventually it would only run at a very low idle, like not getting enough gas. when we take the fuel line off at the carburator there is plenty of gas flowing. This problem got progressively worse a little at a time every time he used the tractor. We are quite sure it is not gas or electrical, but where else could we look.
Any help is appreciated. Harry.
But is there plenty of gas flowing for 2 minutes?Just
a wild guess,the valve in the tank is plugged.
I agree with 504.
It's either fuel or ignition (or both). What did the old plugs look like? What do they look like now? Could be valves or timing, but it isn't back firing so I doubt that's the issue. Air cleaner could be plugged up, making it run rich but you think it's starving for fuel. You should pull all the plugs and see what they look like.
This is just a quick check: Take the air cleaner off, then with it running see if you can get the RPMs to pick up by spraying some carb cleaner in the carb. If the RPMs pick- up, it's starving for fuel. If not, troubleshoot the ignition system.
Throwing parts at a problem like this often makes it worse.
Is the fuel tank vented properly, likely vents through
the cap. Second, I do not know a lot about that Massey
but does the fitting where the line connects to the carb
have a screen in it? I do not see on the parts diagrams
but I just know most Farmalls have them. When they
plug there can be plenty of fuel at the line but it cannot
get in the carb.
(quoted from post at 09:30:00 02/14/23)
Have you run a vacuum gauge on it to see what it's showing?
Sorry for not responding sooner, but i have been away from my computer for a few days. We are going to redo the carb with a complete kit to make sure we have that right. If nothing changes will try a propane torch test, meaning holding the torch with it turned on but not lighting it around the intake manifold. if it start to run better doing that ,then that means it is sucking in false air at the intake and a leak there would mean it is starving for fuel. It may take a few days to get around to that, because its not my tractor and not at my shop.
like i said before any suggestions are welcome and duly noted and I will definitly know how this turns out. Thank you so far.
I had a 400 Farm-All with exactly the same symptoms. The carb float had a leak and rode too low resulting in a rich condition. Also make sure the choke blade is actually opening fully.
