massey ferguson 20
randy1
trying again guys you all advised against the jd 770 so now I found a massey ferguson 20 with loader with a perkins diesel it has little over a 1000 hrs on it good sheet metal and everything works as should it need this to unload 1000 lb round bales and move them into field. what do u think. buying this from a private person. but it is over 300 miles away seen lots pics and guy has been honest I really dont want to drive 600 miles round trip. he will deliver. he is asking 5500 thanks for your input
The MF20 would be sufficient for what you are wanting to do.
I think Tracy may be thinking of a TE or TO 20.
This is a bigger, heavier tractor, 42 HP, comes with PS, live PTO. A shuttle shift would be a plus.
The price sounds at the top, but if it's as good as it sounds, not out of line.
MF 20 Industrial
Make sure the power steering does work before you buy, not a bad price for one with a FEL. Hopefully it has the Perkins 3.152 diesel (they did come with the Perkins 3.152 gas engine also). Good little tractor may need some weight on the rear for moving round bales.
I can't comment on the price, but I have an MF-20. Mine has the Perkins 3 cyl gas engine. I use the tractor as a woods tractor and have moved some heavy loads on a trailer. I love it. Solid machine. My power steering has two cylinders and I hear the turf models have one large one. I mounted two LED headlights on the front and an LED work light and a amber/red safety light on the rear. I had to split mine to do the clutch which wasn't bad due to not having a loader. Buy the service and parts manual from here. Good investment.
