Massey Ferguson 30B
Deno
I have a Massey Ferguson 30B industrial loader tractor with box scraper with hydraulic tilt, depth ripper and teeth - serial number 9A315898. I was told it was a 1977 model. It has forward/reverse pedals on right side. When I step on the forward or reverse pedals there is a long hesitation before the tractor will move. Is this a problem with linkage or could it be something else?
A hotline blue book shows it to be a 1979 model, 79 began at 9A300200, 80 began at 9A326169. 30B made 1976-82. Check all your trans and hydraulic oils pulling drain plugs to see if have water or if oil is old and dirty change oils and filters. Yes check pins and linkage off pedal to see if worn and fix that first. If that doesn"t work post later on MF board.
