David Stobbe
Hi everyone, this is my first post to this forum, I'm looking forward to picking some brains that have more experience than I do.
I bought this tractor last fall, only to find that it had a major power steering issue. It had had a broken power steering cylinder bracket, a cast bracket which the previous owner had repaired. During unloading, the pitman arm pinch bolt was loose, which caused the steering arm to drop and jam against something immovable. I left the tractor where it was until I could reposition the pitman arm and tighten the pinch bolt. When I did so, I also discovered a major leak from the power steering pump.
I also discovered when I tried to move the tractor, that it had no power steering function, even with the pump refilled. Somewhere around this time I removed the front cover from the tractor and discovered that the cylinder bracket was broken again. As I couldn't find one readily available, I took it to a local welding shop that actually understood cast iron and repaired it properly. I also purchased and installed a new power steering pump.
Fast forward to today. After numerous attempts to bleed the power steering system, I have no discernible boost. I jacked the front end and turned the wheel lock to lock numerous times, and the fluid level moved up and down and had the appearance of being pumped. There didn't seem to be much air, if any.
Unfortunately, with the wheels back on the ground I don't think I have any boost at all in either direction.
At first I thought I had some boost to the left, and adjusted the turnbuckle on top of the cylinder as per instructions to encourage right boost, but with no discernible effect. Now the steering seems equally difficult in both directions.
The turnbuckle pins are slightly worn, allowing some slack, and I have not yet replaced them.
Sorry for the long post, any thoughts?
David
David
