Massey Ferguson 85 hydraulic problems
3qranch
I have a MF 85 and the 3 point hitch will not work from the draft control levers. The 3 point will only work if you move the left hand hydraulic
remote up or down. I read a post describing his exact problem but it was from several years ago. Any help with this would be greatly
appreciated.
The DRAFT lever should only be used for ground engaging tools, otherwise it should be down about 1/2 way on the quadrant and left there. With the left lever locked back, the position control lever SHOULD raise-lower the three point. If it doesn't the pump spool valve may be stuck, usually caused by the oscillator drive failing to move the spool valve back and forth like it's supposed to.
