Massey Ferguson 88
Just going by your handle, for what purposes will you use the tractor? That is a Wheatland model so it will not have a 3 point and the tread width is not adjustable. Those Continental and Perkins engines are expensive to overhaul. A photo goes a long way towards getting you a price more in the ball park. Otherwise if it is anything like a 65 it is a good solid tractor. I doubt you will use it as a field tractor, but those Masseys you set low behind the engine and straddle the transmission are a hot ride in summer. Later models that raised you up with your feet above the transmission are much cooler.
