Massey Ferguson fe35 injector pump
R1chard
I have another pump it?s a CAV DPA 3249F040 serial number R23176ZU on the bottom it says PH 30/500/9/1990p is the firing order the same I know every thing else is as far as fitting,
That pump is for a Perkins 4.108, NOT for the Standard 23C. Why not have the original pump repaired? Or is it too far gone. Early 23C used a fixed phase no advance pump, my 1958 35 has it. The late 23C used a pump with light load advance.
I got that pump from a friend other then knowing it would fit that was all i new about it, I already went through mine and get fuel but no pressure, this all started with it acting like it was running out of fuel and quit and when I checked the filter it was half empty so I put a new fuel pump on it and it ran for a half a day and did the same thing so I found a rebuild video on you tube and got a rebuild kit , and took my time to make sure everything was clean and put back thy way it was,now not enough pressure or fuel to start maybe the pump wore out
