massey harris 101 ?
brian 255
I have a friend that lives up the road from me that has an old 101 with a brake peddle on both sides.There is no number stamped on the deck by the pto handle where they normally are.Under the front frame the date indicates 1940,is this the year it was made or has the front been changed?
If it has a brake pedal on rach side it is a 1938 101! Dose it have a flathead 6cyl motor? In 1939 they moved the brake pedal together and called them 101 super! The 1938 should have flat top feners and cast center rear wheels!!
Thanks for your reply's, I guess my real ? was why doesn't this one have serial numbers on the deck.If you look in the book it says 1938 start with 255--- this being the case I have a 1938, but the date under the tractor indicates 1937,it has both brake pedals on the right side. Just seems to be a lot of differences in these old tractors, thanks again Brian
