Massey Harris 44, Conversion to 12 volt
dbmacdon
Hey wondering if anyone has any specific details on how to hook up my new alternator, battery, and resistor for my MH44 12 volt conversion from 6 volt.
I have the brackets almost done to mount the alternator, but want to be sure where to connect the resistor at the existing 6 volt coil, how/where to connect up the single conductor wire from the alternator, what to do with the existing voltage regulator, ammeter, and of course, new 12 volt battery polarity (positive, negative cable connections).
If anyone has some specific, all inclusive directions or diagrams, I"d appreciate a reply either here or to my email at [email protected].
Thanks a bunch
#1 switch your battery ground.
#2 switch the 2 wires on the coil so it will then be set up to work on a - ground system.
#3 put the ballast resister in line with the coil/switch.
#4 If your useing a 1 wire alternator you hook that wire to any place that will be the same as the + side of the battery. Starter button or soliniod etc.
My Massey 44 had an amp meter. Disconnect "BAT" wire from regulator (wire that goes to ammeter) and connect this wire to alternator output. If ammeter shows positive with ignition or lights on, tractor not running reverse ammeter leads.
Remove old regulator.
Points, condenser, and ammeter don't care whether they are 6 or 12 volt.
Starter will turn same direction regardless of ground polarity.
(quoted from post at 09:52:57 09/10/09) #1 switch your battery ground.
Hi, thanks for your reply, haven't got it done yet but thanks for your time.
Dennis
Hi, thanks for spending the time to reply to my inquiry. I haven't completed the conversion yet but hope to get on it soon.
Dennis
