Massey Harris 44
Olie
I put in a new rear oil seal in my Massey Harris 44 and it still leaks. Any ideas what the problem could be. Thanks
What did the shaft surface look like? If a groove was worn on the shaft, you can offset the sealing location on the shaft by making a shim plate to move the end cap out further. A 0.060? shim is usually enough.
