massey harris
WACO
can any body identify this tractor the Frame # is 1244C 2214 The motor # MFSA2446 1336
It has tags but they look alummiun tags can't read anything but the numbers the frame # is 1244c 2214 the motor is a 6cy flat head with a alummiun tags and the motor MFSA 2446 1336.Wondering what kind of hp it has. For some reason it has a 24v generator & starter. Thanks again all help appreciated
From the picture, it appears to be an industrial model. Could the first character be an I instead of a 1? The engine/ sheet metal combination indicates a 44-6. Can you find a serial number stamped to the left of the shifter?
Yes you are right it is a I the # on the left top of the shifter is a I 244G.
2214
And it looks like there is a date on the side of the case the # is H-6-05 thanks again for all the help !
I'm far from being an expert on these. Tags could be aluminum. The ones I've seen were brass. They were made in 55 & 56. As far as the 24 volt system, The tractor had a electro magnet on it that the Air Force used to get any metal off the air strips.
It looks like the military version of the 44-6. It has a Continental 226 CID engine, with about 44 PTO horsepower, a little less than the 4 cylinder 44. The engine was the same one that had been used in the 101 Senior. Probably very rare!
You have a 1955 Massey Harris I-244 Air Force with PTO. There were 242 made with PTO. 708 made in total. They also made them for the Navy. The engine is a 244 cu in Continental. The brackets on the side are for a large magnet that was attached below the frame for sweeping runnways and aircraft carriers. Some had cabs on them as well. Mine is #2154 with a cab. One is restored with working magnet in Wabash Indiana.
Nice rare tractor!!
Appreciate everyone's help on this tractor. It makes me really happy to find out that I have something that might be worth something someday It run and drives good too. Thanks everyone Waco
