Anonymous-0
I have a MF-50, and I need the plate that is located on the bottom side of the transmission. Any help ya'll could give me would be greatly appreciated!!
Maybe some help. That plate will be the same on a Massey 35 or 50. Same tranny/rear end. 35's will be far more common if you're searching bone yards.
Probably the same as many MF tractors. Their MF-236 loader uses the same bolts for the rear mount. On my MF-135 its a flat plate with 4 11/16" holes for the 5/8" bolts and a 3/16" hole in the middle with a 5/32" cotter key through it to let oil spilled from engine or transmission seals drain. Plate probably 1/8" thick.
Gerald J.
If you are talking about the inspection plate you can easily make one out of 1/8" plate. Cut to fit and drill the four bolt holes. Nothign too special about it.
