Massey1080 starter
Okay , so been out using the tractor headed out no troubles, got work done came home shut down, went out restarted to move tractor, started okay, shut down and noted starter still turning, not engaging... pulled battery cable it stopped, reattached still turning, what could it be wires are all tight on terminals, no cracks in wires... wondering why... need some insight...
A low battery can cause a starter to hang in, as can a catch/bind in the solenoid plunger, test battery voltage. A bad switch hanging and providing power to the solenoid could cause it. Test with voltmeter or test light to see if the start terminal is getting power all the time. If so, bad switch or shorted wires. If it doesn't have power, bad solenoid would be the next suspect.
