pbennett135
My massey 175 when it gets warmed up the loader and 3pt works very slow , loader won't pivk up very big load , 3pt very slow have to rev engine full throttle . sometimes won't raise disc, let off throttle 3pt lowers without moving lever.
(quoted from post at 14:24:47 08/25/19) My massey 175 when it gets warmed up the loader and 3pt works very slow , loader won't pivk up very big load , 3pt very slow have to rev engine full throttle . sometimes won't raise disc, let off throttle 3pt lowers without moving lever.
I would consider cleaning hydraulic filters. Is it multi-power or 8spd transmission?
(quoted from post at 00:19:06 08/26/19)
its 8 spd, I was told there is no hyd filters on this tractor, if so where are they, how hard to clean
(quoted from post at 07:41:00 08/26/19)
Well I have the 6spd transmission so can t totally relate. I would bet you still have a filter for your lift pump internally. Which if clogged would affect your 3pt. Also possibly affect remote hydraulics (not totally sure). Mine I have to remove the top cover that the seat sits on to access. Yours may be accessed easier since it s a later model tractor. Definetly get a service Manual and check hydraulic port pressure with a gauge.
(quoted from post at 14:03:57 08/26/19)
I m wrong, mine is a 6 so also, so is there filters in there and how hard to clean
