massy 44Sp.
Have Massy special will drive in any gear around yard but will not pull any implaments. the shaft from the clutch to the rear end is turning but no movment of the tractor. the planitary is turning am lost.
If it has a LPTO.....look for a long lever between the brake pedals....that clutch is slipping. It's located behind the circular plate between the right rear wheel and the transmission/rear end housing, just under the floorboards and beneath the brake pedals. Adjustment is at the base of the long lever, but in many cases, if live pto power is not needed, the clutch assembly can be bolted together, bypassing the live function completely.
Ben
