Math question
I cracked a bunch of walnuts from my first harvest. Curious as to what percentage of the nut was kernel, I bagged the shells in one shopping bag and the kernels in another, then suspended them on a balance consisting of a long piece of oak trim and a pivot point.
The bag with the shells hung 20" from the pivot. The bag with the kernels balanced at 50" from the pivot. All other things being equal, what is the ratio of kernel to hull in my strain of wild walnuts?
Thanks,
Rod Croskery
The Croskery Woodlot
Let me try this. Your working with 20" and 50". A common denomitor would be 10 so, your harvest is 2/5ths shells. Or from each pound of nut crop you get 9.4 oz. of fruit and 6.6 oz of waste. I could be all wrong here, what do you think?? Is it a 40 / 60 split ? 60% fruit?
28.5% kernel? 25% is average for black walnuts.
If the shells are x = 1, then the kernels are
y = 2/5. So the kernels are 40 parts of a total of 140, or 28% and a bit.
Old elementary school problems for kids? Balance factor from pivot is 20/50 =1/2.5, shells weigh 2.5 times as much as nuts harvested, nuts need 2.5 times length to balance. Harvest % about 40% nuts- about the same % as on OT board?. ;-) RN.
By my figures:
11.4 oz shell / lb nuts => 71% shell by weight
4.6 oz kernal / lb nuts => 28.5% kernal by weight
How I got there -
The shells were 20" from the pivot, the kernals were 50" from the pivot when the "system" balanced. Therefore, 20*S = 50*K. We don't know the total weight, so figure S + K = 1 lb.
This:
20*S - 50*K = 0
S = K-1
Combines to:
50*K -20*(1-K) = 0
And we get K = 2/7 = 28.5% kernal
Nathaniel
Somebody check my math, please!
That's not how it goes in school these days. here is a sample question;
You have one bag with 3 3/4 lbs. of walnuts
You have another bag with 2 2/3 lbs. of walnuts
Question; How many bags do you FEEL you have?
Any answer is OK, as long as you share part of the Walnuts with someone that has no Walnuts... The nuts must be shelled first, though...
When you figure out you lost 50% or better in county, state, and federal taxes, fees, permits, licenses, surcharges, excises taxes, etc, then another 10% in shrinkage, dock, moisture, and foreign matter, then spent another 10% in trucking and packaging you might as well stay on the porch and drink another cold one.
Gene
I will offer the same service. 'Cept the percetage of nuts may go down slowly until there is none left. Figure the shells will be safe though... unless I can get them to go through my media blaster. And I will better any other offer by 10 percent....
28.57% Nut
71.43% Shell
Gold Mine=Hers
Shaft=Mine
Aaron
Simple answer:
The distance between shells and nutmeat is 70" and 20" are nutmeat while 50" are shells.
20/70 = nutmeat
50/70 = shells
2/7 = 28.57% nutmeat
5/7 = 71.43% shells
Roughly 1/3 of each unshelled nut is kernel(colonel).
The remainder must be enlisted persons.
Here's an expert on nuts:
Untitled URL Link
Yep, Walnuts will be on the WIC list. along with all the other free food... Half of the folks at the supermarket are on WIC, foodstamps, or some other program...
Deflection in oak trim is negligible. Even a 1" deflection would only shorten the moment arm by .0025 inches.
This is not how it works. The sum of the moments about the pivit is zero, else the rod would tip.
Thus. Weight of shells (WS)* 50in = Weight of meat (WM) * 20
Do some division: WM/WS= 50/20 = 2.5/1
Thus of the whole weight of the nut you can expect 71.4% to be meat and 28.5% shell.
(quoted from post at 00:49:25 10/09/07) That's not how it goes in school these days. here is a sample question;
Question: How do you think the tree feels, having its nuts picked and taken away by the farmer? Write the words to a song you think the tree might sing. (Marks will not be deducted for incorrect spelling.)
:roll: David
