Mccormick Deering Super w4
Deering
Have unseized the brakes and am just about ready to start it up.
I noticed that the v-belt between the water pump/fan blades, and the motor drive pulley on the front of the engine is missing.
Would anyone know the belt that would fit it, or the size of the belt?
Thanks in advance for the help.
I don't know the number or length, but if you got a tape measure,like a seamstress use's, run that around all the pulley, kinda lose, and you got the measurement !
Right here on YTMag. https://www.yesterdaystractors.com/48032DA_Fan-Belt_12640.htm?
gclid=Cj0KCQjwi7yCBhDJARIsAMWFScMcW8EHleJZLxML0dTjemaYc8yrQkA2DjvJyhSbS75d5OF3DyOUHFQaAljmEALw_wcB
Jim
It's the same fan belt as the Farmall H and Super H.
Check the water pump's condition before you waste our time installing a belt. It may be seized, which is why the belt is missing.
You can start and run the tractor for a couple of minutes at a time without the water pump if you're getting antsy to try :)
