McCormick Deering W-6 front engine mount
Oldiron29
A Friend Is wanting to remove W-6 front engine cover to replace damaged Cam gear.
He said front engine mount has to come off first, two bolts from below will not clear it.
Does he need to remove front axle yoke to get these bolt out? any info would be great.
i replaced a camshaft in one a few years ago and dont remember running into that problem. i can look at one in the morning. far as i know remove front pulley and remove front cover. i never touched the front axle.
He said 3 bolts go down into front axle yoke 2 of them are through front engine mount? Heads are pushed up from leaf spring?
Looks to me that you can remove the two bolts on the motor mount and remover it with out pulling the axle. I would however crib under the bottom of the frame tub just to add some stability. Also put a little under the oil pan to support the engine. The bolts are threaded into the axle support and there is one nut and bolt through the front of the frame tube to hold the axle pivot. That should be enough if you support the front of the frame tub.
OTJ
Its been YEARS since we had one, but I do recall the motor mount being part of the timing cover. Seems like we ended up pulling the engine, but heck, we may have been doing that anyways.
the one i did was the super TA model so was problem removing the cover as the mounts are on the side of the engine. the standard has the mount on the front cover after you pull the pully off then it slides off once those two bolts are out. BUT you will need to remove the engine or lift it so the front mount will slide far enough ahead to come of the mount. it will not slide far enough ahead due to the way the tub is made. just remove the nuts off the two bolts and they should drop down enough so mount slides out. might have to remove the centre axle pin and drop the axle down or raise the front up you will see once at it if the bolts will turn.
