McCormick Side-delivery rake parts
Dick S
Need a few things for my old steel-wheel 4-bar McCormick rake. Copied a post a few years back with some suggestions, but now can't find it (of course). Any help would be appreciated.
Thanks in advance.
Really looking for list of sources for such parts, which is what I had before. Rather than posting a shopping list.
I have rebuilt many of them over the years to go to the Amish but am now retired. I never found something like that New teeth are I think still avaible from the Amish but not the clamp to hold them on, One was talking about trying to make them but I don't think he ever got it done. Other than that it is find a parts rake pr populsr items like bushings or springs just have to find a good hardware store and my measurements. Over the years I think I have worked on or rebuilt out of parts machines over a hundred steel wheel rakes including McC. , JD, Case, MM, N I, MH and cannot think if any oher makes But did have a D B rubber tire rake that I used and had to scroung parts for it as none avaible. The drive pawls in the wheels just have to make them. Straight roller bearings I have a friend that used to be able to make but I don't know if he still can. I do have the parts books for your rake yet unless I sold them.
Leroy pretty much has it. There isn't much out there on NOS parts anymore & a parts machine is usually a decent resource for parts. To add a couple resources, there's Duffield Implement in MD. He doesn't list a lot of rake parts at this time, but Mike may be able to help you locate something if you need it. If you need a new flat chain, Farmchains.com is a good place to go for that. Think it's a #50 link used on those four bar rakes. The teeth & retaining clips are getting hard to find outside of the Amish community. Grease cups & fittings are pretty much standard. Bearings will have to be salvaged unless there's one floating around on Ebay. It's possible to find such parts by number doing a search on the Tractor house site. Not always productive, but can return some results on occasion. If all else fails, post back here & someone should be able to figure something out for you.
Mike
Hello Dick, Which parts are you looking for, for the rake, I may have a bunch of new teeth.....do you the part number of the parts you are looking for?
Kevin
