McCromick W6 is a mess
RCompton
This message is a reply to an archived post by LarryM on January 13, 2012 at 22:12:36.
The original subject was "McCromick W6 is a mess".
I just bought a 1952 Super W6 the transmission had water in it and it froze and cracked the bottom by the drain plug but it runs beautiful
That wouldn't be terrible to fix, You could either weld it or braze it. It really isn't structural where the crack is, so brazing would be a decent choice and it could be fixed so that you could never tell that it was cracked. I've brazed cracked engine blocks where someone had attempted to weld them but they would still seep and after brazing, they've been fine for years and no one would ever know they've been repaired unless you removed all the paint.
I had a similar crack in my H transmission and it welded up fine. It was done by a guy that knew what he was doing.
There's about 5 ways to fix it.
Weld it. To do that you would have to drain get all the oil out of the crack or it will leak.
Braze it as already said. You will also have to drain it and get all the oil out of the crack.
Pin it. That would require draining also then drill tap put a bolt in there then cut off smooth and so on. Using a sealing product in the thread each time.
Change the casting with a known good one.
Trade tractor for different one.
Find someone that knows how to braze overhead. Drain the oil & vee it out good. No need to take anything apart except the fill opening to let the smoke out. The heat of the flame will burn the oil out of the crack. When the puddle flows good in an overhead weld you know you have a good bond & seal.
(quoted from post at 07:41:58 02/03/20) It's getting harder and harder to find "Someone who knows what he is doing."
Thing about that is, the vast vast vast majority of these repairs were done by folks who had no idea what they were doing. They were farmers who learned to braze at the school of hard knocks, quite possibly while repairing the cracked diff housing on the tractor.
Point being you don't necessarily need someone who went to years of trade school to effect a repair.
If you were around here, I sure wouldn't mind helping you. It just takes a lot of torch gas. You have to bring the area up to brazing temp (which is a big hunk of cast iron) before braze will flow. It really wouldn't be that bad of a job, but it would take some time getting it up to temp.
Drain all the fluid out of the rear, clean up the area, V out the crack with a die grinder and then start heating it with a torch. The heat will cook all the oil out of the crack and you will get a nice clean repair if you take your time and do it right.
saw your reply on block repair. i have a block that is cracked.could you give me a contact person or phone#. i am in utica,n.y. thank you earl
