MDV FARMALL AND JD D
Bob H.
Hi Guys;Well, as I write this my bil in Ca. is loading a truck with a JD D and a high crop MD. He is DRAINING the rad. and blocks. I told him about the drains on the side of the M, and the rad drain. Also the big plug on the D and the rad drain. He's also pulling the lower hoses off. Is this ok as far as getting back to northern Mn. with out a block getting frozen? Did I miss a drain plug? The high crop "STUFF" is off the tractor, so he is building a crate for that. Thanks Bobmn
Consider turning the engine over a few times when everthing is drained to make sure the water pump isn't holding any pockets.
Is the transmission fluid milky? It might not cause cracks, but a frozen transmission can make the tractor very hard to unload.
Mathias; Thanks for the reply! Good idea about those things. Never thought about the unloading part!! I'll call him in Ca. now and have him ck the fluid. It's 71 above now as they are loading, and it's 18 above in Mn at our farm!! Thanks Bobmn
