riverbend
- Location
- Delano, MN
1940 H. I'm elbow deep in the guts of the back half of my H. The neighbor is going to machine for the worn bull gear hubs and make matching shims. While I'm waiting for him, I'm going to reset the backlash for the ring and pinion in the differential.
Using a feeler gauge is going to take a lot smaller hands or some clever way of reaching down along side the pinion shaft. Using a dial indicator is off by some 15 or so degrees due to the thickness of the gauge stem interfering with the next tooth. How is it supposed to be done ?
Best estimate, the backlash is <0.007 and should be closer to 0.010. I read that moving shims from the left to the right increases the backlash. How do I figure out how much to move the bull pinion carriers to get 0.003 more room ? Or should I move a thick, thin, or medium shim ?
Greg
Greg
