Measuring a Universa
37 chief
I need to replace the U joint on my flail mower. I thought I could just order one, all put together I couldn't find one on the net. How can I determine the size of the one I need. I have to order the parts one at a time, on the net. I have no place here that has those parts. One yoke shaft size is 1 1/8 in. ID. the ID of the spline yoke is 1 3/8 -6 spline Then I need to order the bearings. That will be an act of God if all the stuff fits, after I order it. Need help. Stan
It sounds like you are calling the yokes with the u-joint assembled in them the u-joint. It doesn't surprise me that you are not finding an assembly of the u-joint and the yokes, those parts are generally sold separately
We may be able to help you if give the info on the mower, location of this shaft and a couple pictures. Do you have the parts book for your mower?
So, did you order parts or are you still looking for help?
