I would think so, It would be depending on what you are going to do as far as rpm. Obviously higher rpm is going to produce more thrusts and have a possibility of deforming and allowing rings not to seal but in the antique circle that is a pretty thick sleeve. What classes do you intend to pull and is it turbo or NA? mEl
Yes, was with Art at Troy with his 88 when I first met you. It's been a while now since I've bumped into you. Good luck on your project, Someday may have a dog in that fight also. mEl
