Metal roofing
About 25 yrs ago I put steel roofing directly over shingles. Twice a year, in the spring and in the fall, I get to listen to snapping, and popping sounds coming from the roof. It is annoying to me. If I were to try to sell the house, I would most likely need to do so when the roof is quiet.
I can understand how that could be annoying! One potential solution is to install a proper underlayment or insulation between the shingles and the metal roofing. This can help minimize noise by creating a buffer. If you're considering selling, addressing this might make the house more appealing to potential buyers.
Without going into why
How will 29 gauge residential metal preform bolted directly to clean new half inch OSB and a synthetic underlayment.
IE: No furring strips.
I BELIEVE THE MINIMUM RECOMENDED sheathing thickness is 5/8. Not enough bite on the screws with 1/2 inch osb..
